tab Sucker Moderating Team 32,303 Member For: 20y 11m 10d Gender: Male Location: Brisbane Posted 13/06/08 07:47 AM Share Posted 13/06/08 07:47 AM A significant amount of time is spent by moderators deleting the quotes out of posts where they are excessive or not at all necessary in order to keep threads tidy and easy to read/follow. There is no need to quote the post directly above, it’s safe to assume that you will be on the same topic as the previous post.Also there is no need to quote an entire post, just quote what is relevant and delete the rest.The lessons.....TO ADD NEW REPLY (Appears after the last post on each page)This will launch the Add Reply feature in a new window without quoting any prior posts. The easiest option however is to use Fast Reply - right at the bottom of the page you should see this box...Just click in it and start typing. It only has limited functionality compared to the Add Reply feature, but if you need to access these advanced features you can also launch the New Reply window by clicking on “Use Full Editor” (this will carry over any text you’ve already entered)TO QUOTEThis button automatically quotes the post adjacent to it, and opens a new reply window.This button allows you to select multiple posts to quote. Click this button next to each relevant post (it will change to a darker colour to signify the post is selected) then click on the New Reply button at the bottom of the page, you will then be presented with something similar to this in the new reply window.....[quote]Text sample one[/quote][quote]Text sample two[/quote]You then can enter your responses in the gaps.....[quote]Text sample one[/quote]First response[quote]Text sample two[/quote]Second ResponseWhich will give you.....Text sample oneFirst responseText sample twoSecond ResponseAnd that’s that! 1 Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 16d Gender: Male Location: Zombie Birdhouse Posted 12/11/09 07:11 AM Share Posted 12/11/09 07:11 AM BUMPETH Also when quoting from a long post , just the relevant bits please.Members and moderators alike hate scrolling through an enormous quoteto find a single sentence addressing a single point Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 9d Gender: Male Location: Victoria Posted 16/07/11 02:47 AM Share Posted 16/07/11 02:47 AM There has been some changes to the way in which the quote and reply post functions works.You'll now see 3 buttons under each post. They are... Clicking on the "Add Reply" button will allow you to post a reply to the thread. Clicking on the "Quote" button will allow you to post a reply to the thread AND quote the post in which the button you clicked is located. The Multi Quote procedure is unchanged and the process from Tab's opening post is outlined below...This button allows you to select multiple posts to quote. Click this button next to each relevant post (it will change to a darker colour to signify the post is selected) then click on the New Reply button at the bottom of the page, you will then be presented with something similar to this in the new reply window.....[quote]Text sample one[/quote][quote]Text sample two[/quote]You then can enter your responses in the gaps.....[quote]Text sample one[/quote]First response[quote]Text sample two[/quote]Second ResponseWhich will give you.....Text sample oneFirst responseText sample twoSecond Response 1 Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 6m 30d Gender: Male Location: Southern Highlands NSW Posted 04/11/12 03:39 AM Share Posted 04/11/12 03:39 AM BUMP Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 4m 21d Gender: Male Location: Dé·jà vu Posted 23/10/13 03:45 AM Share Posted 23/10/13 03:45 AM 2013 Bump....Seems to be an influx of late.... Link to comment Share on other sites More sharing options...
