xlnt6 Donating Members 350 Member For: 20y 4m 19d Gender: Male Location: Melbourne, Victoria Posted 25/01/07 11:41 AM Share Posted 25/01/07 11:41 AM Well, I've been driving around with 4.11 diff gears for over three months now and every day I kick myself for not doing it earlier. If cdm is still out there, I conceed your views as I now am a "believer" !!Especially after the bigger turbo which made the boost response a bit lazier, the 4.11 recovers that low down urge nicely. I have a T56 6 speed. That provides a taller overall top gear than the 5 speed.For driving around town and freeway driving I can't recommend it enough. I guess I'm changing gears a bit more than before, but mainly by shifting up to 6th, whereas 6th wasn't really possible til 110km. Now 100km is about 2100rpm, and the ratio works out the same as a 5 speed in 5th with 3.45 diff. Fuel economy hasn't really changed either as the top gear is still tall enough to return good economy.BTW I had originally a 3.45 ratio then tried a temporary 3.7 ratio and finally 4.11. CheersRobin. Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 1m 27d Gender: Male Location: Sydney Posted 25/01/07 12:01 PM Share Posted 25/01/07 12:01 PM I've also had the 3 diffs.The 4.10 was also going to be better with the bigger turbo, so your comments don't surprise.It's sort of like suddenly picking up an hefty increase in torque!With a 3.73 diff 6th at 100kph will be about 180rpm less, so less responsive.My opinion is that 3.90, if available, would be the best option/compromise.Brian Link to comment Share on other sites More sharing options...
simonhoare Member 85 Member For: 18y 5m 14d Location: S.A Posted 25/01/07 12:11 PM Share Posted 25/01/07 12:11 PM the six speeders should have come out with these lower numbers brian or have been an option!!!!! Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 12d Gender: Male Location: OZ Posted 25/01/07 12:15 PM Share Posted 25/01/07 12:15 PM whats the cost of a 4.11 fitted and just the part/s? Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 4m 19d Gender: Male Location: Melbourne, Victoria Posted 25/01/07 12:27 PM Author Share Posted 25/01/07 12:27 PM The 4.10 was also going to be better with the bigger turbo, so your comments don't surprise.True, and I planned to do the diff and turbo in a similar timeframe for that reason. Actually ended up with 3-4months in between, and when it finally happened, it just showed that a bigger turbo upgrade really needs to be done in conjunction with a diff change in order to get the same lower RPM seat of the pants urge as with the OEM turbo.whats the cost of a 4.11 fitted and just the part/s?Don't know about the cost of parts, I was given the bits and had then built into a spare 3.45 LSD by TransDiff in Thomastown for $200. The biggest cost is the fitting, as it's quite labour intensive, about 4 hours, allow $400-$500 to do the swap.CheersRobin. Link to comment Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 13d Gender: Male Location: The Shire Sydney AUS Posted 25/01/07 03:12 PM Share Posted 25/01/07 03:12 PM It seems like you have the complete package robin, Credit to you and car mateHas the backlash improved over the OEM item ???? and what Gearset are you using, is it a case of just a crown & pinion swap or are there mods to be done.. I'm due for itThanks PeteBTW, the box is a Going good.... just the rollover noise on idle sometimes is bit excessive, but still feels very strong it will soon be visiting Mal W for freshen up! Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 4m 19d Gender: Male Location: Melbourne, Victoria Posted 26/01/07 11:29 PM Author Share Posted 26/01/07 11:29 PM Has the backlash improved over the OEM item ???? and what Gearset are you using, is it a case of just a crown & pinion swap or are there mods to be done.. I'm due for itHi Pete, my original diff, while it did have a bit of backlash, didn't cause me any grief, not like I've heard others complaining about. The new diff is the same. You still get driveline clunk on take-up especially noticeable on decel at low speed. The Gearset is still a Dana set - I think ...... (they are available thru most diff shops that build / reco diffs and I've seen them advertised in a few of the mags). Yes, it was just a matter of changing the crown and pinion and having the diff shop set-up the clearances. I also took the opportunity to have the LSD tighten alittle which has helped with straight line traction and hasn't effected cornering (as far as I can tell without being on a track). Beside that nothing else has changed. Except acceleration of course !!!BTW, the box is a Going good.... just the rollover noise on idle sometimes is bit excessive, but still feels very strong it will soon be visiting Mal W for freshen up!Good to hear. What can Mal do to fix this problem permanently ??? As I understand a blueprint job will only address it for a while, before the noise comes back ??? Mine does it, and started doing it within 3k-5k from being brand new.Cheersin.Rob Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 9m Gender: Male Location: Sydney NSW Posted 27/01/07 12:58 AM Share Posted 27/01/07 12:58 AM Would you recomend the 4.11 to those of us with less power? If it matches the T56 better like you say I might look at it for mine... Ive changed ratios on previous rides and always worked out well down low Link to comment Share on other sites More sharing options...
86gav 69 - PSI Donating Members 263 Member For: 19y 4m 27d Location: Gladstone QLD Posted 28/01/07 05:53 AM Share Posted 28/01/07 05:53 AM Also interested to hear thoughts on this as im looking for a bit more urge down low.CheersGav Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 1m 27d Gender: Male Location: Sydney Posted 28/01/07 06:54 AM Share Posted 28/01/07 06:54 AM If it matches the T56 better like you say I might look at it for mine... Ive changed ratios on previous rides and always worked out well down low←A point to note is that if you want to run down the 1/4 you will be slower, as you will need to use 5th gear ... will cost you up to .3 to .5 of a second. Brian Link to comment Share on other sites More sharing options...
