cdm Member 886 Member For: 22y 2m 1d Posted 08/05/03 03:00 AM Share Posted 08/05/03 03:00 AM Does anyone know how exactly the traction control works and if it could be bad for the engine if its is activated often. I ask this cos I do a lot of "spirited" driving and the traction control is always cutting in. I just wonder if it could have any long term negative affects on the car. Link to comment Share on other sites More sharing options...
rjs Donating Members 525 Member For: 21y 11m 16d Location: Sydney Posted 08/05/03 03:35 AM Share Posted 08/05/03 03:35 AM Just take the TC off when in 'Spirited Driving' mode. Link to comment Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 21y 8m 17d Location: Wellington NZ Posted 08/05/03 04:36 AM Share Posted 08/05/03 04:36 AM From my understanding it either retards timing slighty to reduce tourque or applies the brake to the wheel losing grip. It wont hurt the engine one bit. Link to comment Share on other sites More sharing options...
Guest StaggerLee Guests Posted 08/05/03 04:54 AM Share Posted 08/05/03 04:54 AM Yeah, I thought it cut in and stopped the power being put down. I'm not totally sure though... If this is the case and whether it does have a negative impact on the engine who knows, but it is better than the alternative. That is, having your car wrapped around a pole... Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 7m 20d Gender: Male Location: stanthorpe wine capital of qld. Posted 08/05/03 04:58 AM Share Posted 08/05/03 04:58 AM THE TRACTOIN CONTROL ON THE BA CONTROLS THE INJECTORS AND THE THROTTLE THOUGH THE DRIVE BY WIRE MODE, that's WHY WHEN YOU REALLY GIVE IT HEAPS OUT OF A CORNER LIKE I DO ALOT THE CARS APPEARS TO MISS. Link to comment Share on other sites More sharing options...
Unigroup Member 25 Member For: 21y 8m 11d Location: Sydney Posted 08/05/03 05:52 AM Share Posted 08/05/03 05:52 AM Like iaschmidt said it’s controlled via the electronic throttle. If the wheel speed sensors detect a difference in velocity between the front wheels and the rear then it knows the rear wheels are spinning.Some cars chop the ignition timing or just shut down a cylinder or two. Link to comment Share on other sites More sharing options...
cdm Member 886 Member For: 22y 2m 1d Posted 08/05/03 11:43 AM Author Share Posted 08/05/03 11:43 AM Interesting stuff. I sounds kinda like an F1 car when it cuts in. I like it, but it is annoying when you want to have even the slightest bit of fun. At least we can turn it off! :D Link to comment Share on other sites More sharing options...
Ford_Power Member 798 Member For: 21y 8m 11d Posted 10/05/03 01:50 AM Share Posted 10/05/03 01:50 AM No, traction control should have no negative effects on your BA. As stated by some guys above, the power is cut by closing the electronic throttle AND/OR fuel cut AND/OR applying brakes depending on how severe the wheelspin is. Some lesser aftermarket traction control units can hurt your engine. This happens because they only cut the fuel to maybe one or two or three cylinders, but not cut the spark. This results in the fuel in the cylinder being burned on one cycle, and on the next, the very small residual fuel in the still ignites (albeit with very little resulting power) The reason this is bad is because that cylinder is now running VERY lean, and we all know what happens when you run an engine too lean :( The BA combats this by cutting fuel to select ALTERNATE cylinders. This way there is ALWAYS fuel in the cylinder and you wont go burning piston tops and valves cdm, If I were you, I'd keep planting the right foot mate :D Link to comment Share on other sites More sharing options...
cdm Member 886 Member For: 22y 2m 1d Posted 10/05/03 02:35 AM Author Share Posted 10/05/03 02:35 AM Cheers Ford Power, good explanation. It's good to have some fun every now and then. :D Link to comment Share on other sites More sharing options...
