Rough T56 Gear Changes...
Ralph Wiggum
  • Moar Powar Babeh
  • Member For: 19y 2m 25d
Hey Guys since fitting my Mal Woods T56 ive noticed over the last 7000k's that the shift had got progressivly worse and harder to get gear when driving the car hard. I was a tad concerned so i though i have a quick look before getting on the phone to Mal and i found two obvious problems....
1. The clutch fluid was Sh*t i had gone black and didnt smell to good. I used cheapo BP brake and cluth fluid as it was all i had when i fitted the box. Flushed and bleed it with some good PBR fluid....Instant 100% improvemt for $8 and 15 minutes work
2. I pulled the surround off from around the gear stick and to my surpise found that the gear stick had a lot of movemnt where it bolts onto the box. I got out a 13mm spanner and got a good 5 turns out of the bottom bolt and about 2 on the top one before they where tight. I think the rubber damper/cusion plate assembly had taken set and compressed slightly from the heat of the box. Once again 100% better than before.... :msm:
So im wrapped the box is shifting better than new and all my dramas where due to simple little issues that anybody could sort out.... :spoton:
  • Gold Platinum Member
  • Member For: 20y 5m 22d
I had gone black and didnt smell to good.
Hehee, as oposed when it is another color and smells good :P
Thanks for the tips even though mine is fine I might check that bolt as it can be a little sloppy at times. Thanks good tips. Only took 15 mins to bleed line?
  • Moar Powar Babeh
well i think ford recommend every two years for the brakes but the fluids usually nackered by then...so i'd probably do it once a year cause its so easy... :spoton:
Maybe ask Mal Woods what he recommends..just dont use crappy year old fluid.... :fishin: ....i should slap myself..... :pinch:
