DaRKy Member 13 Member For: 20y 11m 19d Posted 08/04/06 08:23 AM Share Posted 08/04/06 08:23 AM hey guys,I have a totally stock 2003 auto xr6trecently I have noticed when I accererate and back off I can hear alot of turbo flutter, is this normal? I was under the impression you basically wouldn't hear anything in a stocker. should I be taking it to ford to sus out or is it normal? Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 3m 18d Gender: Male Location: Perth, WA Posted 08/04/06 09:29 AM Share Posted 08/04/06 09:29 AM I heard it all the time in my stocker, do you have a cold air induction setup?Unless you actually hear rushing air while under boost I wouldnt worry. Link to comment Share on other sites More sharing options...
homerj Member 52 Member For: 21y 2m 1d Location: Berwick,Melbourne Posted 08/04/06 10:22 AM Share Posted 08/04/06 10:22 AM Got exactly the same car except for a BMC air filter and I hear it all the time - look forward to it actually...... 1 Link to comment Share on other sites More sharing options...
BOV Member 142 Member For: 19y 1m 11d Posted 08/04/06 10:47 AM Share Posted 08/04/06 10:47 AM Apparently if you have a pod filter (K&N, apexi etc) you can hear the flutter or "whoosh" more... my car is stock too and I want to fit a pod soon just to see what noise it makes (as well as performance) Link to comment Share on other sites More sharing options...
DaRKy Member 13 Member For: 20y 11m 19d Posted 08/04/06 11:18 AM Author Share Posted 08/04/06 11:18 AM strange just went for another drive up the road and its back to normal, before every time I accelerated and backed off was getting really loud flutter, now nothing :S Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 3m 18d Gender: Male Location: Perth, WA Posted 08/04/06 11:31 AM Share Posted 08/04/06 11:31 AM Things to note:You will hear it loudest when your not trying to listen to it... and the loudest it will be is when the boost has hit a maximum and you release the throttle. It will not be very loud at high rpm though. Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 10m 11d Gender: Male Location: brisbane Posted 08/04/06 11:43 AM Share Posted 08/04/06 11:43 AM if you get flutter (gobble gobble) your car is doing what its meant to be doing... the gobble gobble sound is good 1 Link to comment Share on other sites More sharing options...
bangm001 Member 307 Member For: 19y 6d Posted 09/04/06 12:23 AM Share Posted 09/04/06 12:23 AM I heard somewhere on this forum, that is this begins to occur much louder than normal, or previously, then you may have loose/missing turbo bolts and or loose manifold bolts, try checking these all first, they are located under neath the heat shields on the LHS. b**ch of a job realy, but I think that you will find that these will be loose. When was your last service? Look, id just do it anyway.. Also, the cooler weather seems to have a slight effect on this if they are all normal. Let us kow how you go!Cheers! Link to comment Share on other sites More sharing options...
Shockwave-T Member 96 Member For: 19y 5m 17d Location: Melbourne Posted 10/04/06 03:19 AM Share Posted 10/04/06 03:19 AM I noticed mine was making some pretty nice sounding spool up sounds, but after taking it in for the 15K service, they tightened the intake manifold bolts and it stopped. So no more spooling sounds, but the flutter is still there and pretty audible. My car's a stock 6spd manual. Link to comment Share on other sites More sharing options...
jasper361 Member 407 Member For: 19y 10m 26d Location: Brissy Norf siide Posted 10/04/06 04:49 AM Share Posted 10/04/06 04:49 AM I am confused! I thought 'turbo flutter' was bad, as per this extract from the turbosmart website.The “flutter” noise reported by many excited enthusiasts may sound good but is actually very unhealthy for the turbo. The “flutter” occurs when upon shutting the throttle, air caught between the free-spinning turbo and the shut throttle. The consequent back pressure forces the air back through the turbine blades. This process, more commonly called “cavitation” places enormous loads on the turbo and can lead to premature wear of the turbo bearings and other load-bearing components. The cavitation or “flutter” can be fixed by either fitting a blow-off valve onto a system that hasn’t got one, or making sure the blow-off valve is matched to the output of the turbo and is not working outside its flow capacity and ensuring the blow-off valve is set up correctly.Or is the flutter you are talking about actually the Wooosh sound of the BOV venting into the intake? Link to comment Share on other sites More sharing options...
