  • Colossal Member
  • Member For: 20y 10m 12d
I fitted some PBR Premium brakes this arvo... full kit with slotted rotors, PBR calipers and braided lines.
I managed to figure out how the old ones came off and how the new ones fitted on fine. It took a few hours and a few swear words, but the end result looks mint. :msm:
My question is this: When you took it for a drive did you notice a difference in the way the brakes work? Does it feel firmer or spongier?? How far do you have to push the pedal to get them to work hard?? :thumbsup:
I ask this because, after bleeding all four calipers twice, it seems the brakes are much spongier and I have to push the pedal further to get them to work. The car pulls up fine, I can even get the ABS to start dancing... it brakes in a straight line for me too which is an even bigger bonus with no brake shudder and I doubt I would get them to fade.
Do I need to bleed them again?? :msm:
I was using clear hose so I could see if any bubbles were coming out, and the second time I went round all the brakes no air bubbles were visible at all.
If I'm not happy with the difference I will most likely take the car somewhere and get them fixed (still cheaper than the 2 hours labour they quoted to fit them).
Any thoughts?
Will post pictures soon
Steve
https://www.fordxr6turbo.com/forum/topic/23660-a-question-to-those-who/
  • Member For: 22y 3m 5d
Definitely keep bleeding the brakes... that's all it is.
It may look like there is no air, but it can take a long time for it to come out.. esp if you let the master cylinder run dry and suck air in from there...
Ross
  • Colossal Member
Yeh I made sure it wasnt run dry. It will have to be later I think... cbf any more lol
Up to anything mate? :thumbsup:
  • HgAg soldier
  • Member For: 21y 11m 24d
Did you go through the bedding in procedure?? I was told that you should go easy on them for the few hundred kays.
Might need to check for air in the lines too, I did this twice and found a few bubbles. Certainly made a difference with the pedal.
My brakes are a bit spongier than the standard ones but still pull up alot stronger. You will get used to it.
Enjoy
Kaine :thumbsup:
  • Colossal Member
Thanks kaine, they are second hand so bedding in doesnt matter really. I wasnt sure about whether it was something I will have to get used to or not. I have driven cars with much much worse brakes than this though!
<{POST_SNAPBACK}>
I'd have no problem helping you mate but im off to a friend's place tonight for her birthday party...
Definitely keep bleeding them though...
