What Turbo
blackwrx
  • Member For: 19y 11m 17d
what type of turbo does the Xr6T use? I was told that it was a garret GT40 or something but I could not find any details in my little book.
Are the turbos running about 6 psi standard from the factory?
Has anyone boosted there XR6T up with a manual bleed valve?
What sought of boost can the stock internals etc handle?
  • Forum Superhero
  • Member For: 21y 2m 9d
Like a kid in a lolly shop hey! :w00t2:
I know its a Garret, either T04 or T40 cannot remember.
6psi factory, in most T's.
From experience these days you cannot 'Bleed off' the boost like we used to in the old days, as it sends the pcm haywire and you will probably loose all your boost completely.
The only way these days is to run a piggyback or edit style controller for extra boost.Whilst you could technically still bleed boost off it would still need to be contolled someway via the pcm, and you would I suggest need some form of fuel rising regulator.
These days with technology you will do more harm than good by not doing it properley from day 1.
:w00t2:
  • Toughest BA Turbo
  • Member For: 22y 1m 11d
Garrett GT3540.
It's really a hybrid turbo; internal wastegate;designed for low boosted 4L.
Try reading these old threads.
http://www.fordxr6turbo.com/forum/index.ph...2470&hl=garrett
http://www.fordxr6turbo.com/forum/index.ph...1008&hl=garrett
http://www.fordxr6turbo.com/forum/index.ph...1102&hl=garrett
Brian
Guest PSIXR6
  • Guests
What Brian said, :spoton:
I know that the factory boost is set to 5-6psi. But the turbo is working alot harder than that, as the intercooler drops 4psi across its core.... not to good :msm:
So in actual fact the reading of 5-6 psi manifold pressure is about 10psi at the turbo outlet. This turbo is good for 2bar though or 30psi :msm:
  • Toughest BA Turbo
30psi sounds pretty good, it would be nice to see what can be done with a less restrictive intercooler then.
<{POST_SNAPBACK}>
I doubt you'd go anywhere near that boost because the exhaust housing just won't flow well enough... I.e you hit a brick wall.
My view is that once you go over say 16lb boost it is worthwhile doing housing posting/swing valve mods to get better flow.
Brian
