Mondie Firm Member Donating Members 2,924 Member For: 22y 2m 17d Location: Adelaide Hills Posted 06/04/03 10:15 AM Share Posted 06/04/03 10:15 AM l was wondering if anyone knew if the diff used in the GT is the same as in the XR6T. l read in the GT review in Unique Cars that the diff is made by "Dana", l thought BTR made the XR6T diff.If its different then maybe the GT wont have the same driveleine bangs/clunks that our car has from the low spec diff. l think our car is actually getting worse, or l have become accustomed to the car and the diff now seems that much worse. On the cold mornings we are starting to get, the gearbox/diff feel like something from the Flintstones until things warm up a bit. Anyone else noticed this?It's a big disappointment to me on such a great car. :( Link to comment Share on other sites More sharing options...
harasn Used to work at the Ford Proving Ground! Lifetime Members 306 Member For: 21y 10m 23d Gender: Male Location: Geelong Posted 06/04/03 10:55 AM Share Posted 06/04/03 10:55 AM appart from the actual gear ratio the 2 diffs are basically the same. they are made by Dana! The reason the xr8-gt doesn't have the driveline shunt is because it has been calibrated out though the ECU with the electronic throttle. You know how in your car if your smooth in applying the throttle it doesn't bang, that's exactly what the v8's ECU does. It slows down the throttle changes to stop the shunt. Apparently the driveline in the v8s is actually worse for the shunt than the turbos and lower! why they didn't calibrate it out of all the cars I don't know but I hope they do in the near future as I like you think its getting worse over time! Link to comment Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 22y 2m 17d Location: Adelaide Hills Posted 06/04/03 11:19 AM Author Share Posted 06/04/03 11:19 AM that's interesting harasn,l hope Ford does do some reprogramming of the ECU to remove the shunt as l assume this could be uploaded to our cars. It beats me why Ford never did this for the XR6 in the first place, its a stupid problem to have in such an otherwise refined car and it doesnt even need to be there l really notice the shunt now and its annoying, keep thinking how great the car would be if it didnt clunk and bang. Not impressive at all. Link to comment Share on other sites More sharing options...
WBT56 Mal Wood Automotive Member 457 Member For: 22y 2m 11d Gender: Male Posted 07/04/03 09:33 AM Share Posted 07/04/03 09:33 AM appart from the actual gear ratio the 2 diffs are basically the same. they are made by Dana! According to the Ford website the GT and XR6T both have the same ratio. (3.45:1) The XR8 has a taller ratio.(3.23:1) Link to comment Share on other sites More sharing options...
