Brake Shims Rattle
Soul Reaver
  • Member For: 20y 4m 13d
Hi one and all,
First I must say I love this site, the mightly XR6 Turbo and the look HSV's give you when you are flying past them :nono:
Now onto the reason im posting here, every since ive had the car (new in august 04) I have had a brake shim rattle :sick: everytime I have travelled over a bump the front brake shims rattle making a metal on metal clapping noise very annoying when the windows are down (can only hear when the windows are down from inside car) and I must sound like a 10 year old car.
Now on my first 3k service I advised of the issue the brake shims and clips holding them on were replaced and I was advised all fixed, too bad no body told ford it was not fixed as I got home and found out it was still there (just not as loud). Went back to ford about 1000k later and again the clips and brake shims were replaced, yet again I drive home and find noise still there :gooff:.
So I go back again about 500k later and advised of problem, I go to pick up the car and was told the front disc's have been machined, HELLO when did I say I had brake shutter :nono:, I spit the dummy and they replace the brake shims again while I was waiting and getting very pissed off.
The service manager then comes over and advises they have replaced the brake shims but the problem will come back again as Ford have advised this as a known issue with all the BA's and there is currently no fix WTF!!! :spoton:
Also when I drive home find noise is still there loud as every.
1. Why has it taken 3 goes at it to say it is unfixable.
2. WTF is it not fixable.
3. Why have I not heard of this problem before on other BA's (yes I have searched and being reading this forum as of Auguest).
Sorry for the long post but just wanted to get it off my chest and ask if anyone else has this problem or is Ford full of :pooh:.
Thanks in advance,
  • Member For: 20y 5m 19d
SR,
I think this is the problem I have been looking for. Have searched until blue in the fingers and poked and prodded under the car. Thought it might have been exhaust heat shield or brake dust covers from other forum comments. Dealer has had one go at it but they did not ID it as brake shims.
Same deal - rattles under car over bumps, only just heard with windows shut. If only one front wheel hits bump (such as lane marking reflector), only that side rattles.
Now, what the hell is a brake shim?
  • Member For: 20y 8m 5d
I had this issue too (well, still have it but not as bad), a simple test is to go find some rough road and see the problem occur then go back over it with your foot slightly on the brake and see if you find it a whole lot quieter. That's how my service dealer bugged the issue.
Bugeyes
Guest TRACK
  • Guests
When I drive over a rough piece of road, my brakes are fine but the sunroof rattles along with the door lock button assembly on the drivers door!! :blush:
Track
Thanks guys for the comments,
It is exactly was bcr01 and the others said when go over bump with no brake pressure noise, if go over with brake pressure no noise.
About the revised brake shims, FORD (according to service guys at the dealer I went to) have trialed 3
1. Orginal gear.
2. Brake Shutter supposed fix :spoton: and
3. Brake shims rattle supposed fix.
1 and 3 have been placed on my car without any success :spoton:
I havn't heard of the glue from PBR but :nono:
Mine does stop with light brake pressure so looks like this is the problem.
Anti-squeal sounds good. Can someone point me at what to glue? Pretend for a second that I am mechanically challenged - I still can't work out what a shim is. Well I did once :thumbsup:, but he really looked like a woman.
