Tolgz Member 36 Member For: 21y 1m 2d Posted 06/12/05 08:43 AM Share Posted 06/12/05 08:43 AM hi,after deciding on the purchase of an xr6 turbo, is was jus wondering, if an auto T would make the same fluttering sound, from the blow off valve, as a manual T would, wen u are shifting gears through tip tronic mode ? if not, how would u actually make it flutter ? Link to comment Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 9m 6d Gender: Male Location: Mackay NorthQueensland Posted 06/12/05 09:05 AM Share Posted 06/12/05 09:05 AM I think the fluttering you are talking about, is the bov not working properly, sometimes they stick and you get a flutter through the impeller when the air gets pushed back when the buttewrfly gets shut. or some big power it might not be big enough. imo the auto makes it when you back off fast if it is sticking. David Link to comment Share on other sites More sharing options...
Tolgz Member 36 Member For: 21y 1m 2d Posted 06/12/05 09:13 AM Author Share Posted 06/12/05 09:13 AM im not quite sure, but I think the BOV makes the fluttering noise, when acceleration pressure is released. So I assumed that, since in tip tronic u dont get your foot off the accelerator, there woudnt be a flutter. Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 1m 2d Gender: Male Location: Sydney Posted 06/12/05 09:16 AM Share Posted 06/12/05 09:16 AM hi,after deciding on the purchase of an xr6 turbo, is was jus wondering, if an auto T would make the same fluttering sound, from the blow off valve, as a manual T would, wen u are shifting gears through tip tronic mode ? if not, how would u actually make it flutter ? <{POST_SNAPBACK}>The only time the turbocharger/wastegate will flutter is when the throttle is closed while the turbo is spooled/spooling/pressurising.Therefore, a manual car will flutter a lot more, as you lift off the throttle when you change gears.And when using the tip-tronic in a auto, it will not flutter, as the throttle is staying open, and therefore the turbo is still pressurising.Theoretically, its not the turbocharger fluttering, its the air reverberating off the intake wheel on the turbocharger.Hope this helps. Link to comment Share on other sites More sharing options...
Cowiesxr6t Member 249 Member For: 19y 8m 6d Gender: Male Location: Mackay Qld Posted 06/12/05 09:21 AM Share Posted 06/12/05 09:21 AM Mine has done it since day one and still stock standard and has 69,000km on the clock. Turns heads....hehehe.Cowie Link to comment Share on other sites More sharing options...
T007 Woooooooosh Donating Members 734 Member For: 19y 7m 26d Location: Sydney Posted 06/12/05 09:23 AM Share Posted 06/12/05 09:23 AM Only way you will get a flutter in an auto Hold it in first gear till it gets to about 5500 rpm then release throttle you will get a slight flutter but not as much as in the manual happy fluttering Link to comment Share on other sites More sharing options...
Guest xrtwpn Guests Posted 06/12/05 09:33 AM Share Posted 06/12/05 09:33 AM You can get flutter ask anyone that knows my car you can hear it down the road and its auto Link to comment Share on other sites More sharing options...
T007 Woooooooosh Donating Members 734 Member For: 19y 7m 26d Location: Sydney Posted 06/12/05 09:58 AM Share Posted 06/12/05 09:58 AM You can get flutter ask anyone that knows my car you can hear it down the road and its autoI think he is talking about a standard one Link to comment Share on other sites More sharing options...
jEtONiT Donating Members 1,817 Member For: 21y 3m 26d Gender: Not Telling Location: next door.. Posted 06/12/05 10:02 AM Share Posted 06/12/05 10:02 AM yeh standard ones sound madd.. a mate of mine did a standstill and as he let go of throttle the "compressor surge" (hwich im pretty sure makes the flutter sound) went off its head. Link to comment Share on other sites More sharing options...
T007 Woooooooosh Donating Members 734 Member For: 19y 7m 26d Location: Sydney Posted 06/12/05 10:12 AM Share Posted 06/12/05 10:12 AM yeh standard ones sound madd.. a mate of mine did a standstill and as he let go of throttle the "compressor surge" (hwich im pretty sure makes the flutter sound) went off its head.What is a standstillWhat noise are you talking about Link to comment Share on other sites More sharing options...
