Head to Head Oil Testing.
xrhp6
  • Member For: 21y 1m 30d
Important article on oil testing comparison's of synthetic oils carried out on a Dyno here in Melbourne, those considering oil change should read.
Appears that a light weight oil such as an 0w-40 or 5w-40 could damage motor till warmed up.
Would recommend that Manafacturers oil be used at all times.
http://www.performanceoilnews.com/oils_against_oils.shtml
Have just purchased an 12/02 XR6T and are thankfull that someone else has taken the depreciation.
Regards
xrhp6
  • Member For: 21y 4m 14d
Try buying the specified oil from Ford. No one can supply the spec listed in owners manual. The dealers all use different brands and viscosity. I'm still trying to work it out.
  • ASHA - Anti Stooge Hunter Association
  • Member For: 21y 8m 12d
ive spoken to 2 dealers, one told me that 15-50 is fine for the car, one told me they use FULL synthetic !
Go figure that out ??!!??
  • 2 weeks later...
Ford Dealers who use Castrol, I am told use Castrol FMX which is synthetic, not available to the public, I intend to use Castrol Magnatec 10w-40 as advise by Castrol and Ford Dealer.
Have currently in motor FUSCH Performance Plus, appears to be good oil has synthetic additives, am using to flush out any crud.
Interesting that a Turbo dealer recommends Castrol GTX3.
What oil do others recommend.
15000 K's is to long between changes.
When looking at Tech Data Sheets on oil's look at the ACEA rating,
A1 Fuel Economy Petrol
A2 Standard Performance level
A3 High Performance and / or extended drain.
B1 Fuel Economy Deisel
B2 Standard performance level
B3 High Performance and / or extended drain
B4 For direct injection passenger car diesel
E1 Non Tyrbo charged light duty
E2 Standard performance level
E3 High Performance extended drain
E4 Higher performance and longer extended drain
E5 (1999) High performance and longer drain plus American/Api performances.
GOOD READ is Engine Oils what you need to know,
www.chris-longhurst.com/engineoil_bible.htm1
Regards
xrhp6
