Ebay Brake Upgrade-is It Possible?
ravenhard
  • Member For: 16y 11m 21d
Was looking at upgrading my disc to slotted rotors and then found this on ebay. Now I always thought if you increased the size of the rotor, you had to change your calipers. This seller is saying different. He is selling the kit for $350.Is it true and is that a good price? Has anyone got them?
FORD FALCON FRONT BRAKE DISC UPGRADE
TO SUIT
BA FALCON
UPGRADE YOUR STANDARD 298MM FRONT BRAKES TO A MASSIVE 330MM DISC ROTOR
THIS IS A DISC UPGRADE KIT - USING YOUR EXISTING CALIPERS.
THIS KIT INCLUDES
2 X FRONT 330MM X 28MM VENTED, SLOTTED PERFORMANCE ROTORS
2 X ADAPTER BRACKETS, SUPPLIED WITH BOLTS
2 X ADR APPROVED AND STREET LEGAL S/S BRAIDED BRAKE HOSES
  • Replies 29
  • Member For: 19y 7m 17d
The calipers are the same, its the change in brackets that allow them to fit.
  • Member For: 21y 10d
It will not make much if any difference to your braking performance.
It is a cosmetic change and should be avoided.
If you want to upgrade the braking performance, then do it properly with DBA4000 rotors and soem decent pads as a basic upgrade.
Going to Alcon/Brembo's and larger rotors will improve the performance further.
The best way to improve the stopping distance is better tyres.
Guest newl
  • Guests
330? Will that fit under an 18" factory rim (assumption) still? My F6 has 325mm rotors (same size as the DBA 4000s) afair and the calipers barely clear as it is now.
  • Member For: 19y 7m 16d
I have been looking into this as well as a basic upgrade. The rotors / brackets wont be ADR compliant that's all. The more metal the better the ability to absorb and dissipate heat, therefore a bigger rotor should technically always be better.
Ebay Link? Will help.
I didnt want to post it to be accused of ebay advertising. this aint my item for sale.. :)
ebay link
might have to ask the seller more info like if its ADR compliant and even if he has a shop to fit them...
  • Dropping a turd
  • Member For: 17y 3m 28d
That will be a good upgrade. They will fit under the 18s fine. The braided lines are a bonus. That is a good cheap kit. Just fit some good quality pads, like police spec etc. and your car will stop great.
  • Member For: 21y 4m 22d
Correct!
The larger rotor in this upgrade will give extra thermal capacity, however unless getting serious pads there is no real benefit.
