All Activity
This stream auto-updates
  1. Today
  2. I had the same issue with my FG and found it was the alternator. At idle it would drop down into the 11volt range. New alternator and all good. My mate with a 2011 XR6T had the same issue. His alternator was fine but the ECU voltage would tank at idle into the 11volt range, He had a underdrive kit on his so he purchased a smaller pulley for the Alternator and voltage never dropped below 13.5v. No more idle problems!
  3. Yesterday
  4. morning all, happy Thursday 🛃
  5. proud to be a filthy animal looking excellent bro! I was kinda shocked how much my garage/shed echoed until I put all my stuff in it, now it hardly does... I'm sure yours will be similar, but the biggest problem you'll have is how loud the cars are, I'm sure... ear-muffs will be the go
  6. Here's a pic ya filthy animals
  7. Finished moving everything in there today, got the dyno in place although I think I'll move it over a little bit. You wouldn't think moving a dyno 30 metres would take much, but it was a bit of a mission. Will get to setting it up properly next week when my extension cord arrives. Ha it'll be interesting to see how loud it is, the shed already echos pretty good.
  8. Last week
  9. morning all, happy Wednesday 🛂
  10. Decided to move the dyno to the shed today...wishing that I had bought that forklift a few months ago. Haven't got it set up yet but will have it on the ground tomorrow with the fan and computer bit along side. Also ordered parts for an extension cord for it, $380 later lol, anyway here's a pic or 3
  11. morning all, happy Tuesday 🚾
  12. Sounds like a failing trans solenoid.
  13. Keirrah
    2012 fg xr6t
    Bit of a weird one and any form of direction is appreciated. Saturday the car come up either dsc fault and trans fault, system comms fault flashed on and then off. Car clunked into drive, auto zf6 box, went into P,R and N fine, went into limp mode, wouldn’t recognise tryna manual shift gears either and had P0657 code with OBD scanner. Put a new battery and alternator, cleared the codes and took it for a drive. Car is driving fine now no clunking it’s recognising the manual shift mode however is bringing up dsc fault when I press the brake pedal and transmission fault only when car is in reverse. Bringing up new code U0100 Any ideas are appreciated
  14. exactly... every fart has a slight risk attached
  15. Glad to know. Knowing my luck it would quickly turn into a game of look what I had for breakfast
  16. well, it's not very nice to your children, but still, like everything to do with farts, it's funny
  17. My kids wanted to play a game so I said, "I've got a game, it's called Guess What I Had For Breakfast?!". The rules are, I do a fart, everyone takes a sniff and whoever guesses what I had for breakfast is the winner. My wife doesn't approve and wants to know wtf is wrong with me?! Surely I'm not alone in thinking it's a hilarious suggestion?!
  18. Hey mate just wondering if you resolved your issue as I currently have the same issue with identical symptoms. Have replaced coils and plugs with no improvement
  19. The OEM BOV is designed to trigger itself opening when vacuum is applied to the port, e.g. it'll hold closed until it see's a vacuum source (assuming the seals around the piston are holding the air from getting past it, which is the only weak point, not like other BOV's that use a spring to hold pressure against boost.
  20. Yea im slowly working that one out, they seem to be more of a problem than anything else. Do you guys know that the stock xr6t bov piston actually runs sideways so to speak so the piston cant actually be pushed open by boost pressure, it could potentially just leak past the o-ring that seals it when its shut. Not sure if other oem bovs work like that but it seems like a pretty good idea to me. Aftermarket should make them like that. I might chuck the stock one back on and see how it goes.
  21. morning all, happy Monday 🚼
  22. Best just to have no BOV,
  23. I have a gfb dvx diverter/bov in place of the oem borgwarner bov that's part of the compressor housing and it has been working fine, well it wasnt opening under boost and causing a big boost leak. I was suspect that it could have been leaking and I had pressure tested turbo pipework and checked all plenum hoses and fittings and found nothing. I took dvx apart and put in a extra spring to make it really stiff and hard to open. It fixed it yaaa, I havnt had much luck with bovs on this barra, my Greddy type r 50mm leaked and when I put a stiff spring in it wouldnt open and this dvx has started to leak after a short amount of time too.
  24. Hope its not something more sinister like a wheel let go.
  25. Fair enough.
  26. The tuner I have will not push a ba past 13 pound as he has said that's his limit for longevity and anything over that will be a ticking time bomb. He has got 1 car at 400hp that has done over 400 thou and has been running that for many many years (running original diff and transmission)
  27. morning all, happy Sunday 🚻
  28. @kenna802 whats wrong with 17 psi?
  1. Load more activity
