Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 13/05/14 04:51 AM Share Posted 13/05/14 04:51 AM Trendsetters,I've been on a quest to replace the leaking Eng Oil/Trans Fluid thermostat valve on my 06 BF F6.Ford have discontinued the Valve and now offer a replacement pipe setup.The issue is there are two styles of Pipe, One is to Suit a Zf Trans and The other is to suit cars fitted with an Engine oil cooler.There doesn't seem to be (as far as I can tell) a piping setup for both engine oil cooler and trans cooler.Is anybody able to post up some pics of the pipe work on the LH side of the engine (under the manifold) for an BF F6 (or otherwise) fitted with a factory eng oil cooler and a ZF6?This is the offending part that ford no longer sell. It take in coolant for both the eng cooler and the trans cooler.KGO 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 12d Gender: Male Location: Perth Posted 13/05/14 05:48 AM Share Posted 13/05/14 05:48 AM Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 13/05/14 05:50 AM Author Share Posted 13/05/14 05:50 AM Thanks Arron,Thats the setup I have now. Ford have deleted the valve. I should have been clearer.Is anybody able to post up some pics of the pipe work on the LH side of the engine (under the manifold) for an BF2 F6 (or otherwise) fitted with a factory eng oil cooler and a ZF6 but not fitted with the factory thermostat valve assy? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 12d Gender: Male Location: Perth Posted 13/05/14 06:03 AM Share Posted 13/05/14 06:03 AM Just piss of the thermostat and run it all in series.Manual with cooler has no thermostat Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 12d Gender: Male Location: Perth Posted 14/05/14 03:05 AM Share Posted 14/05/14 03:05 AM So Luke what have you decided to do Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 14/05/14 03:36 AM Author Share Posted 14/05/14 03:36 AM Just decided to have a coffee. 2 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 14/05/14 04:50 AM Author Share Posted 14/05/14 04:50 AM Im hoping somebody will post some pics so I can determine the coolant flow path through the two coolers.It appears to be-> hot coolant from engine - oil cooler -trans cooler - return to water pump. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 12d Gender: Male Location: Perth Posted 14/05/14 06:32 AM Share Posted 14/05/14 06:32 AM Trans will probably be hotter, you would want it going through there last.Are you still going to use a thermostat Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 14/05/14 06:33 AM Author Share Posted 14/05/14 06:33 AM Nope, Mine is leaking coolant and they are discontinued from Ford. If I could find one I wouldn't need to piss about setting up new hosing. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 12d Gender: Male Location: Perth Posted 14/05/14 06:42 AM Share Posted 14/05/14 06:42 AM Wouldnt it be the same as an I6, so N/A 6.. I will have a look at ours tonight. There would be thousands of cars on the road that may need that part. Link to comment Share on other sites More sharing options...
